What happens to a process when the node fails and failover takes over?
Solved2.27K views19th October 2023Failover process automation
bruno santos [SLC] [DevOps Advocate]1.30K 9th June 2023 0 Comments
In a case like MAM - Media Asset Orchestration, if the main node fails while the process is running what happens with that process?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 19th October 2023
Emmanuel Dal [SLC] [DevOps Member]4.65K Posted 19th October 2023 0 Comments
Bruno,
When standby node becomes online, the process will still be running.
In case the process was busy executing script to initiate actions such as the conversion of a file, then the processing of that asset could fail.
It all depends on how the application has been implemented. There are definitely options to support recovery in such a situation.
