What are the system requirements for installing DataMiner?
Solved1.38K views18th June 2024
-4
Dilip Bharadwaj [DevOps Member]8 16th June 2024 0 Comments
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 18th June 2024
Debeuf Klaas [SLC] [DevOps Member]2.01K Posted 17th June 2024 0 Comments
Hi Dilip,
You can find the requirements in our DataMiner help, see https://docs.dataminer.services/user-guide/Reference/DataMiner_Compute_Requirements.html.
Regards,
