WebServices GetVisioForViewCached SOAP Method Format
Solved62 views21 hours agoSOAP Visio web services
Martin Vrzba [DevOps Advocate]843 2 days ago 0 Comments
we are unable to get the WebServices v1 Method GetVisioForViewCached to work, we're getting an HTTP 500 Internal Server Error response (The type Skyline.DataMiner.Web.Common.v1.DMAVisio[] may not be used in this context.), while the same method and parameters does work for the Json interface and the Method GetVisioForView does work well with SOAP Interface.
Can anyone provide a working example for the GetVisioForViewCached SOAP method and/or replicate the issue?
Thank you.
Martin Vrzba [DevOps Advocate] Selected answer as best 21 hours ago
Wout Mahieu [SLC] [DevOps Catalyst]11.50K Posted 21 hours ago 1 Comment
Hi Martin,
There seems to be an issue with the serialization of the response when using the SOAP API. I have created a task for us to fix this, we will let you know here when a fix has been implemented.
Martin Vrzba [DevOps Advocate] Posted new comment 21 hours ago
Martin Vrzba [DevOps Advocate] commented 21 hours ago
Hi Wout, thanks for the testing and confirmation.
