Web Visual not showing the same Visual as Cube
Solved1.21K views5th March 2024parametercontrol Visio web interface
Daniel Lentoiu713 22nd February 2024 0 Comments
Hi all,
I am retrieving some info from a Demodulator and I am showing part of this info into a Visio on top of the element.
While using Cube, I get the correct output on the Visio but on webpage the same Visio does not fill in the details.
Cube
vs Web.
These are just some ParameterControl ShapeData fields.
Any thoughts on this ?
Thanks.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 5th March 2024
Toon Casteele [SLC] [DevOps Enabler]7.37K Posted 22nd February 2024 0 Comments
That's surprising. Could you report this issue through our technical support? Thanks.
