Web Interface is showing nothing in cube.
Solved3.39K views18th July 2023web interface
Pascal Puzio [DevOps Advocate]20 11th October 2021 0 Comments
Hi all,
When I try to see the Web Interface of different elements, the pages showing nothing.
When my colleague does the same on his cube, the web page will be displayed as expect.
Is there a setting in my cube/account which prevent me to see the Web Interface?
Thanks.
Pascal Puzio [DevOps Advocate]20 Posted 13th October 2021 0 Comments
Hi Michiel and Michiel,
Thank you both for you suggestions. I did check the rights, i'am like my colleague admin of the system. And we have both the same rights.
Also did a compare of files in the folder like you mention. they are the same.
So this morning I de-install the cube, and download the cube, installed the cube, and all is working fine, all the web interface pages are working as expected.
It looked that something in my previous version of the cube was not working as normal.
