Web interface inaccessible from DataMiner Cube
Solved2.16K views7th December 2023
Daud Ahmed [SLC] [DevOps Member]404 10th November 2023 0 Comments
Any idea how to make web interface accessible within DataMiner Cube for iDirect IQ200 modem? Web interface(http and https) works as expected for all other elements hosted on same DataMiner and also using any third party browser iDirect Modem web interface is accessible from same DataMiner server.
We have tried following options in the code.
;Web Interface#https://[Polling Ip]/login.html;Web Interface 2#https://X.X.X.X/login.html;Web Interface 3#https://X.X.X.X:443;Web Interface 4#https://localhost”
Web interface 1, 2 and 3 are inaccessible while we are able to reach localhost on web interface 4.
Web bowser engine is also set to Chromium.
Web interface View page source shows: <html><head></head><body></body></html>
BR.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 7th December 2023
Bert Vandenberghe [SLC] [DevOps Enabler]10.11K Posted 15th November 2023 1 Comment
Hi Daud,
Have you also tried with the Edge engine? The Chromium engine is a bit outdated, and maybe the webserver is not accepting this version… If you choose Edge, it’s using the latest version installed on the OS, Chromium is something distributed by DataMiner and therefore older than the Edge option.
Bert
Daud Ahmed [SLC] [DevOps Member] commented 17th November 2023
Hi Bert,
Thanks for the response, after investigating more it turns out to be certificate issue not DataMiner issue.
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 13th November 2023 0 Comments
Hi Daud. Are you able to access the webinterface using another browser on the client machine where Cube is running? The client machine (not server) has to be able to access the device, as otherwise it will not be possible to open the web interface.
Tom Waterbley [SLC] [DevOps Enabler] Answered question 13th November 2023
Daud Ahmed [SLC] [DevOps Member]404 Posted 13th November 2023 0 Comments
Hi Tom,
We are running DataMiner cube on same server where DataMiner is installed, and we are able to access webinterface using other browsers.
Daud Ahmed [SLC] [DevOps Member] Answered question 13th November 2023
