Web Hooks / Incoming HTTP Requests
Solved1.84K views2nd May 2025Connector HTTP incoming Webhooks
Nick Chirumbolo [DevOps Advocate]1.04K 21st November 2024 0 Comments
I've found some older questions/requests for Connectors to be able to listen to incoming POST requests such as those sent via a WebHook. Was this ever implemented? Or is this something that can be done via Data Sources or something like that?
Relevant links:
Dataminer HTTP webhooks - DataMiner Dojo
How to integrate 3PP system/application with DataMiner using WebHook? - DataMiner Dojo
Dataminer HTTP(S) Webhooks – DataMiner Dojo
Thanks!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 2nd May 2025
Baptiste Pattyn [SLC] [DevOps Advocate]5.86K Posted 22nd November 2024 1 Comment
Hi
I do not know if connectors support this but you can do this with User-Defined APIs: User-Defined APIs | DataMiner Docs. These allow you to expose an automation script that an HTTP call can trigger.
Hope this helps.
Nick Chirumbolo [DevOps Advocate] Edited comment 5th December 2024
Nick Chirumbolo [DevOps Advocate] commented 22nd November 2024
Thank you, this does help as a workaround. We've also been looking at the Generic Webhook Alarm Table.
