web.confg settings cleared after upgrade
Solved400 views22nd January 2026Dataminer upgrade IIS
Chris Glover [DevOps Advocate]1.87K 25th November 2025 2 Comments
I've just built a DMS, using the 10.4 installer and some Ansible scripts. As part of the scripts, they set the X-Frame-Options and X-Content-Type-Options headers in the web.config file in C:\Skyline Dataminer\webpages. This is as per the BPA recommendations and https://docs.dataminer.services/dataminer/Administrator_guide/Security/Advanced_security_configuration/WebServer_security/HTTP_Headers.html
Once clustered, the (still virgin) DMA was upgraded to 10.5.12. This removed the custom settings recommended by the BPA. Easy enough to resolve, but it would be preferrable if these settings were not lost when an upgraded is applied.
Please can these settings be made the default, as per the BPA recommendations?
Chris Glover [DevOps Advocate] Posted new comment 22nd January 2026
Seppe Dejonckheere [SLC] [DevOps Enabler] commented 22nd January 2026
Hi Chris,
I checked with the team and the custom settings should be retained when upgrading. If they were cleared, that's an issue.
We also bumped the priority of the item on our backlog to set the headers by default.
Kind regards,
Chris Glover [DevOps Advocate] commented 22nd January 2026
Thanks Seppe!
Seppe Dejonckheere [SLC] [DevOps Enabler]2.78K Posted 5th December 2025 0 Comments
Hi Chris,
I understand that it's inconvenient having to apply the same settings after each upgrade. I also agree that you shouldn't even have to configure these settings, they should be the default.
I believe this item is already somewhere on the backlog, but I'll check with the development team to see if we can raise priority.
Kind regards,
Chris Glover [DevOps Advocate] Selected answer as best 22nd January 2026
