Visual Studio – Unable to create Unit Test
Solved3.23K views24th December 2020Unit Test Visual Studio
Jens Vandewalle [SLC] [DevOps Advocate]10.00K 24th December 2020 0 Comments
I’m trying to create a unit test for a QAction but receive below message.
the system cannot find the file specified 0x80070002
Are there some settings that I need to enable to make this work?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 24th December 2020
João Severino [SLC] [DevOps Enabler]14.78K Posted 24th December 2020 0 Comments
Hi Jens,
Have you tried the steps of the answer to this question Visual Studio fails to create Unit Tests – DataMiner Dojo?
Brecht Deconinck [SLC] [DevOps Member]1.37K Posted 24th December 2020 0 Comments
Have you checked if the .NET framework is enabled in visual studio for .NET framework projects?
You can do this by enabling the ‘.NET desktop development’ option via the Visual Studio Installer.
Brecht Deconinck [SLC] [DevOps Member] Answered question 24th December 2020
Jarno Lernou [SLC] [DevOps Enabler]6.08K Posted 24th December 2020 0 Comments
Hi Jens, this question looks similar to another question.
Can you check if the accepted answer solves your problem?
Jarno Lernou [SLC] [DevOps Enabler] Answered question 24th December 2020
