Visual studio new Automation Script Project Template
Solved1.92K views26th June 2025DIS Automation From Scratch
Michael Loidolt [DevOps Member]97 28th February 2025 0 Comments
Hello
Since updating to the new DIS version, I have no longer been able to create an automation from scratch. The references in the Solution Explorer no longer match. The structure no longer fits either. Has anything changed ? Maybe I' m making a mistake too, but it' s always been pretty ease to create on automation from scratch !!
Felix Wesemeier [DevOps Catalyst]2.53K Posted 28th February 2025 0 Comments
Hi Michael, there was a thread not long time ago: DIS: template for Automation and user Defined API not working anymore - DataMiner Dojo
-Disable loading new templates on VS startup (DIS Setting>Templates)
-Remove Template Nuget V2.x version: dotnet new uninstall Skyline.DataMiner.VisualStudioTemplates
-Install the V1.0.18 version: dotnet new install Skyline.DataMiner.VisualStudioTemplates::1.0.18
Felix Wesemeier [DevOps Catalyst] Edited answer 28th February 2025
