Visual Studio fails to create Unit Tests
Solved3.50K views14th December 2020protocol TDD Unit Test Visual Studio
6
Thijs Vanovenacker [SLC] [DevOps Advocate]2.71K 14th December 2020 0 Comments
While following the Dojo learning course: Creating unit tests using the MSTestv2 framework – DataMiner Dojo
I came across some issues with Visual Studio when I tried to create my unit tests.
As explained in the video, I tried to create a unit test by right-clicking on the method  --> "Create Unit Test"
After confirming with the default settings, I receive following Error code:
Running VS as Administrator does not solve this issue...
Below you can find some more information on my version (VS Professional 2017)
Can someone help me out? Thanks
Thijs Vanovenacker [SLC] [DevOps Advocate] Selected answer as best 14th December 2020
Michiel Clepkens [SLC] [DevOps Advocate]1.51K Posted 14th December 2020 1 Comment
Hi Thijs
To solve this problem, I had to install the ".Net desktop development" workload. This installation can be done using the Visual Studio Installer. A small remark is that I'm using VS Pro 2019.
Hope this will help you out!
Thijs Vanovenacker [SLC] [DevOps Advocate] commented 14th December 2020
Thanks Michiel! I was able to install the “.NET desktop development” via:
“Tools” –> “Get Tools and Features…”
Now I can continue to “Arrange, Act, Assert” with Unit Tests in VS!
