Visual Studio dll reference
Solved1.65K views14th February 2023Visual Studio
Ross Elliott [DevOps Advocate]1.15K 9th September 2022 1 Comment
I may be testing the ‘there’s no such thing as a stupid question’ expression but here goes…
This morning I’ve imported an automation script but Visual Studio isn’t referencing the DataMinerSolutions.dll. I have loaded it into the solution correctly and it’s referenced in the script. There’s no import errors/invalid or dll not found errors etc.  I’m not sure why I can’t use it. I’d appreciate any advice, it doesn’t seem to have happened to anyone before when searching through VS/stackoverflow communities so I expect it’s something obvious!
I should mention it’s fine on the agent, this is just editing on my local machine connected with DIS.
Thanks!
Ross Elliott [DevOps Advocate] Selected answer as best 14th February 2023
Ross Elliott [DevOps Advocate] commented 9th September 2022
Yes, I had to ‘unhide all folders’ on the solution and then add it to the dis references, which of course makes sense! Thanks
Ive Herreman [SLC] [DevOps Enabler]14.52K Posted 9th September 2022 0 Comments
Hi Ross,
Is it possible that you have added the reference in the ClassLibrary project, instead of the automation script project of your solution?
e.g.
