visual studio – dataminer templates are not showing up
Solved2.23K views10th July 2024Templates
komala allanki dheena bandu52 8th July 2024 0 Comments
Hi Team,
When I select File > New > Project in visual studio (2022 community version), template for dataminer is not showing up. DIS installation is also success and can successfully connect to DMA as well but when I try to create a new project , I don't see any template for dataminer (eg. DataMiner Automation Script Solution). Please help me on this.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 10th July 2024
Felix Wesemeier [DevOps Catalyst]2.54K Posted 9th July 2024 0 Comments
Hi Komala,
please verify that your NuGet Package settings are correct.
The Packet Source can be found here: Prerequisites | DataMiner Docs
https://api.nuget.org/v3/index.json
The settings can be found here: Configuring Microsoft Visual Studio | DataMiner Docs
Default package management format to "PackageReference"
Then you should be able to find the templates after a Visual Studio restart.
You can also trigger an template update via DIS>Settings>Templates>Update
Best regards,
Felix
Felix Wesemeier [DevOps Catalyst] Answered question 9th July 2024
