Visual Overview – Setting card variable in new EPM card not working
Solved1.90K views14th July 2023EPM Visual Overview
Alex Collantes [SLC]24 27th May 2022 0 Comments
Hi all,
I’m having some trouble using this feature: Making a shape pass a value to a local session variable in a new card (dataminer.services)
I am trying to set the card variable “CORE” used in the CCAP/RPD Association page of the EPM Visio from the Hub view which uses the Hub Visio. This is the shape that navigates to the EPM card and opens said page (Visio attached to Hub view):
The navigation works fine and the correct page opens, but the cardVar is not set in the EPM card. This cardVar is used normally in the EPM Visio to filter the table and works as expected there. Here is the filter used:What could be the issue here? Has this feature been tested to work for EPM environments?
Thanks in advance!
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 2nd June 2022 1 Comment
Hi Alex,
Thanks for bringing this up.
After simulating this internally, I can confirm it is a software issue caused by an inconsistency in the way cards are opened. Could you create a task for this on collaboration? We’ll report back here once it’s resolved.
Alex Collantes commented 2nd June 2022
Hi Sebastiaan,
Thank you for looking into this. I created a task for this issue as requested.
