Visual Overview – Is it possible to create a matrix shape by using the source and destination tables
Solved2.59K views25th January 2021Matrix Visual Overview
Jens Vandewalle [SLC] [DevOps Advocate]10.07K 25th January 2021 0 Comments
I found that it's possible to link a shape to a matrix parameter where using the matrix component is mandatory. Is it possible to have more or less the same behavior in Visual Overview by only using the source and destination tables?
Michiel Vanthuyne [SLC] [DevOps Advocate] Answered question 25th January 2021
Michiel Vanthuyne [SLC] [DevOps Advocate]4.82K Posted 25th January 2021 0 Comments
It's not possible to do this directly, but you can create a router control configuration using the two tables, and embed the router control configuration in the visual overview.
