Visual Overview – How to show element alarm severities without creating an alarm filter
Solved1.72K views20th May 2021Visual Overview
Jens Vandewalle [SLC] [DevOps Advocate]9.85K 20th May 2021 0 Comments
I found a Visio where different alarm severities are shown by making use shape data label AlarmSummary and custom alarm filters.
Is it possible that I can show the same for an element without creating alarm filters?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 20th May 2021
João Severino [SLC] [DevOps Enabler]14.52K Posted 20th May 2021 1 Comment
Hi Jens,
Would the Info shape data with the options of ELEMENT STATISTICS help in your use case?
You can find more details on this help page and also this help page
Jens Vandewalle [SLC] [DevOps Advocate] commented 20th May 2021
Exactly what I needed. Thanks!
Jeroen Geldhof [SLC] [DevOps Enabler]5.51K Posted 20th May 2021 0 Comments
I think that would be a new feature.
I’m also only aware of the option with the alarm filters.
Jeroen Geldhof [SLC] [DevOps Enabler] Answered question 20th May 2021
