Visual Overview – Element name from element ID
Solved2.01K views18th July 2023Visual Overview
Ailton Luz [SLC] [DevOps Member]51 13th July 2021 0 Comments
Having the element ID how do I get the element name? Element ID is in a parameter, and I want to execute a script with the element name as an input.
Jens Vandewalle [SLC] [DevOps Advocate]10.07K Posted 14th July 2021 1 Comment
Another way is to adapt your script and make a method that figures out if name or ID is used
    private static IDmsElement GetElement(IDms dms, string elementInfo)
if (elementInfo.Contains("/"))
DmsElementId dmsElementId = new DmsElementId(elementInfo);
if (dms.ElementExists(dmsElementId))
return dms.GetElement(dmsElementId);
else
throw new ElementNotFoundException(dmsElementId);
else
if (dms.ElementExists(elementInfo))
return dms.GetElement(elementInfo);
else
throw new ElementNotFoundException($"No element found with name '{elementInfo}'");
Ailton Luz [SLC] [DevOps Member] Posted new comment 14th July 2021
Ailton Luz [SLC] [DevOps Member] commented 14th July 2021
Hi Jens, in this scenario I can’t change the script.
