Visio: VdxPage and Execute on same click
Solved1.31K views15th June 2023Visio
Thomas Warnez [SLC] [DevOps Advocate]791 15th June 2023 0 Comments
when I have above settings on a shape in visio only the execute is being performed. The popup never showed up. Is this to be expected behavior?
If this is expected, any suggestions to have both with one click in visio?
Thomas Warnez [SLC] [DevOps Advocate] Selected answer as best 15th June 2023
Ive Herreman [SLC] [DevOps Enabler]14.71K Posted 15th June 2023 0 Comments
Hi Thomas,
That’s a known limitation.
Jochen did manage to find a solution to this (link).
