Visio: two seperate sets on same element when clicking shape
Solved1.96K views12th July 2023Execute set Visio
Gerwin van der Kamp [DevOps Advocate]4.09K 21st April 2022 0 Comments
I'm trying to set two parameters when clicking a shape. One is working with the execute but how do 1 add the second set?
it's to the same element but different pid i tried:
Set|dma/Eid|1205|SHUFF-A01|NoConfirmation|-Set|dma/Eid|1206|SHUFF-A01|NoConfirmation
but that only did the first set after asking for Confirmation.
How can i do two sets to the same element with one shape set?
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 21st April 2022 1 Comment
Hi Gerwin,
As far as I know this is not available out of the box. A workaround could be to launch a script upon pressing the button which does the parameter sets.
Gerwin van der Kamp commented 22nd April 2022
Hi Sebastiaan,
Thanks, i already had a little suspicion that it would be going down this road.
