Visio Parameters not working correctly
Solved2.39K views29th August 2023Cube Monitoring app Visio
Amer Hodzic [DevOps Member]784 24th August 2023 0 Comments
Hi Dojo Community
I have a weird issue with visio, cube and webmonitoring app.
When I try to make a shape open a certain page on a certain view, I tried setting the shape data to: View -1|3. The issue is that this does not open the specific page.
I have also tried: View -1, NavigatePage 3. This does not work also.
NavigatePage 3 does not work also.
NavigatePage asi-umschalter does work in cube but in the web monitoring app I get an error in the browser console that asi-umschalter is not int32 value when the request is made.
If there is any more information needed, please let me know.
Thanks in advance
Amer Hodzic [DevOps Member] Selected answer as best 29th August 2023
Amer Hodzic [DevOps Member]784 Posted 24th August 2023 2 Comments
Hi Karel,
So at the moment this one works in cube:
But this one does not:
The Dataminer version is: DataMiner (10.3.0.0-12822-CU1)
Thanks
Karel Lodefier [SLC] [DevOps Member] commented 25th August 2023
Hi Amer, the “View -1|3” setup is supported in Cube and should be available in the mentioned 10.3.0 version (as I tested in 10.3.8). Based on your feedback this doesn’t seem to be the case. Can you please report the issue to techsupport@skyline.be for further follow-up?
Related to using Visio in the Mobile App: currently this isn’t supported to navigate to specific pages of other elements/services/views/… . It will currently navigate to the card of the defined shape data. Feel free to request this feature in the DataMiner Feature Suggestions (https://community.dataminer.services/feature-suggestions).
Amer Hodzic [DevOps Member] commented 25th August 2023
Hi Karel,
I already reported it Techsupport and got told to come here.
In regards to the web apps it is in the same view just different page and if that was the case I would understand but I think it exists and it has a bug as in the browser console I do get an error stating that it is expecting an int32 value but it is receiving the “asi-umschalter” string which throws an error.
Thanks for the help so far.
Karel Lodefier [SLC] [DevOps Member]724 Posted 24th August 2023 3 Comments
Hi Amer, shape data “View: -1|3” should work fine in Cube.
Of course with the condition that the root view has a Visio with (minimum) 3 tabpages. Can you confirm you have similar setup? Which DataMiner version are you running?
I do notice this isn’t working in the Monitoring App, let me check this internally.
Amer Hodzic [DevOps Member] Posted new comment 24th August 2023
Amer Hodzic [DevOps Member] commented 24th August 2023
Hi Karel,
The root view has 5 tab pages and when I have it written like that the shape disappears in cube and becomes non editable in edit mode and non selectable
Karel Lodefier [SLC] [DevOps Member] commented 24th August 2023
Hi Amer, can you please share a screenshot of your implementation?
Please see the Answer I posted with the screenshots
