Visio Low-Code Element Linking
Solved1.52K views26th August 2024low code app Visio
James Stokell [DevOps Member]493 3rd May 2024 3 Comments
I’ve been using the ‘Element’: ‘*|’ shape data to put users at the visual overview when they click on the shape, and this has been working fine in the Dataminer Cube app, but doesn’t work when I display the visio in the low-code app, clicking the shape brings the user to the url …/service/124403/251/child/ for example, and says ‘Select a page to view service parameters’.  Is there a way to force the low code user to the visual overview for that service instead?
Thanks, James.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 26th August 2024
Klaas Dewitte [SLC] [DevOps Advocate] commented 6th May 2024
Could you share the setup that you are currently using with the shape data?
James Stokell [DevOps Member] commented 7th May 2024
Hi Klass, how would you like me to do that, what would you like to know? I can’t upload files here so probably easier to email you the visio if that’s possible?
Klaas Dewitte [SLC] [DevOps Advocate] commented 8th May 2024
Hi James
It will indeed probably be the easiest to send over the info and Visio via email. The best way to do so is ending it to our support inbox: support.data-exploration@skyline.be
Klaas Dewitte [SLC] [DevOps Advocate]952 Posted 21st June 2024 0 Comments
Hi, in mobile visual overview, element links will always link to data page of the monitoring app. There is currently no way to have it link to the visual page without also changing the Cube behaviour.
A solution could be to use the Hidden=Cube|Mobile option: https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/miscellaneous/Conditionally_showing_or_hiding_a_page_of_a_Visio_drawing.html#depending-on-the-dataminer-client-application-that-is-being-used
This could allow you to have different pages for cube and mobile and have different behaviours.
Now I should warn that we currently have an issue in mobile Visio that makes it so its impossible to have a element shape also have a link (have link and element shape data), this will not redirect.
