Visio – How do I display a variable linked to a SetVar drop down box?
Solved1.69K views19th December 2023Dynamic Shape SetVar variable Visio Visual Display
Amber Rowe [DevOps Advocate]575 18th December 2023 0 Comments
In this example, my goal is for the placeholder [var:MyVar1] to display the text in the drop-down menu "LDC_ENC_491". Can anyone assist with this?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 19th December 2023
Gelber Mahecha [SLC] [DevOps Enabler]2.03K Posted 18th December 2023 1 Comment
Hi Amber,
Could you please try using ':' instead of ';' in the SetVar shape data? (i.e. MyVar1:[Param:16618/149,1400]
Best Regards,
Amber Rowe [DevOps Advocate] commented 18th December 2023
Thank you so much! I can’t believe it was just that simple!
