Visio Element with Alarm Count for a View
Solved1.48K views27th August 2024visio parameters
Joshua Baranoff6 3rd June 2024 0 Comments
I'm trying create an element with the alarm count for the View.
I found this available for an element (found with the Skyline Visio for Microsoft Platform Drivers)
Any suggestions?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th August 2024
Miguel Obregon [SLC] [DevOps Catalyst]23.81K Posted 3rd June 2024 3 Comments
Hi Joshua,
You could use the shape data Info (see Make a shape display information about the item is linked to). For example, if you would like to display the number of critical alarms for the element where the shape is linked to, you could use the following shape data:
Element: [this element] Info: ELEMENT STATISTICS:[#CriticalAlarms]
Hope it helps.
Joshua Baranoff commented 3rd June 2024
This will only work for a single element. I am trying to do this for several elements that are part of a View. Is there a way to select the statistics for a View group of elements?
Figured it out…
View: [View ID Number}
Info: VIEW STATISTICS:[#CriticalAlarms]
Miguel Obregon [SLC] [DevOps Catalyst] commented 3rd June 2024
Hi Joshua,
Indeed, you can retrieve view statistics as well.
