Visio and connector color
Solved1.55K views23rd August 2024
Cedric Buerfent224 19th April 2024 3 Comments
Dear,
I know how to color a rectangle or circle etc shape.
But I am not able to color a connector (link). Is this possible? If yes, how?
Regards Cedric
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 23rd August 2024
Klaas Dewitte [SLC] [DevOps Advocate] commented 22nd April 2024
What do you mean with connector, could you post the shape data of the shape you are trying to colour.
If it is a shape that is linked to an element or simular, you could use the “NoAlarmColorFill” option to not have that influence the colour: https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/reference/Overview_of_page_and_shape_options.html#noalarmcolorfill
Hi Cedric,
I see that this question has been inactive for some time. Do you still need help with this? If yes, could you answer Klaas’s questions? Or if no more information is needed, could you select his answer to indicate that the question is resolved?
Marieke Goethals [SLC] [DevOps Catalyst] commented 23rd August 2024
Klaas Dewitte [SLC] [DevOps Advocate]952 Posted 25th April 2024 0 Comments
If this is not the case, can you post the shape data that is currently used?
