Virtual IP for OS management with RDP
Solved2.17K views18th July 2023network adapters rdp virtual ip Windows
Patrick van de Leur 16th July 2021 0 Comments
For one of our customers I have the following question, they have a redundant dataminer system (main/backup) with multiple network cards.
The elements use the virtual IP of the redundant system to communicate with dataminer.
But for management of the underlying windows OS, using RDP they have two separate IP’s. This is done with a different network card on a different subnet.
Is there a way to create a Virtual IP for this as well? So that they will always connect (with RDP) to the active system with a single IP?
Best Regards,
Patrick
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 16th July 2021 0 Comments
Hi Patric,
This is possible.
I believe the information captured here is what you are looking for.
