Virtual element with element connections in timeout
Solved2.63K views7th March 2023element connection timeout virtual element
6
Daniel Martinez [DevOps Enabler]144 2nd March 2023 0 Comments
How is possible that a virtual element goes to timeout? There are any ways to investigate the root cause of this behavior? Could it be a driver problem? Note that virtual element has some element connections configured. Could it be related to elements connected?
Laurens Moutton [SLC] [DevOps Enabler] Answered question 3rd March 2023
Bruno Dias [SLC] [DevOps Member]2.39K Posted 2nd March 2023 1 Comment
Hi Daniel,
Could be that your virtual element is running a connector that is making use of call in a QAction (NotifyDataMiner 106) that raises a timeout alarm in a specific situation?
If the connector contains code like this, it could be the origin of the alarm.
Bruno Dias [SLC] [DevOps Member] Answered question 2nd March 2023
Daniel Martinez commented 3rd March 2023
Hi Bruno,
I’ve checked the driver but it has no NotifyDataMiner call on it and has no code that you share. To update element state, in QActions parameters are passed as “inputParameters” and after its values are checked. Depending if a parameter is different to normal value, a “SetParameter” is done. So I understand that there’s no way to create a timeout state with this code.
Note that same parameters passed are the triggers.
