Viavi Return-Path Monitoring Modules HCU200 and HCU204
Solved2.24K views19th July 2023return path spectrum analysis spectrum analyzer
Dominique De Paepe [SLC] [DevOps Advocate]216 7th December 2020 0 Comments
Confirmed the integration over Viavi PathTrak Monitoring Server, glad to learn if we could also consider to integrate these modules directly in DataMiner.
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 10th December 2020 0 Comments
Hi Dominique,
DataMiner can be integrated with any product from any vendor, irrespective of the interface or protocol required, and irrespective of whether that is proprietary or standard.
Checking the datasheets available on the Viavi website, I couldn't find any conclusive evidence that there is an API or interface available to interface with these systems.
If you have the manual for these systems, we could have a look at these and see if we can find any more information there. Alternatively, you can reach out to your systems supplier or vendor to see if there is an API available.
