Verifying and dropping keyspaces for logger tables on Cassandra Cluster
Solved2.47K views25th April 2025CassandraCluster keyspaces logger table
Jan-Klaas Kesteloot [SLC] [DevOps Advocate]1.61K 13th November 2024 0 Comments
On a DMS with Cassandra cluster, I want to keep my database lean & healthy.
When downgrading to a connector version without logger tables, how can I check if the keyspace  for these logger tables (sldmadb_elementdata_<dmaid>_<eid>_<tableid>) in Cassandra still exist?
Next, how can I drop that data and these keyspaces?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 25th April 2025
Matej Plakalovic [SLC] [DevOps Member]696 Posted 13th November 2024 0 Comments
Hi Jan-Klaas,
I did a quick test.
Three elements were created with a version that includes the logger table (Cisco Manager v5.1.7.25). Key spaces were created.
After that, the versions were reverted to the version without the logger table. The key spaces were not deleted.
Because of that, they were manually removed using the 'DROP KEYSPACE' cqlsh command.
It seems that the logger table key spaces were not dropped even when the elements were deleted, until recently RN40523...
In case there are a large number of logger table key spaces that need to be deleted, manually doing it is not ideal. I have written a bash script that can automate this process.
Matej Plakalovic [SLC] [DevOps Member] Answered question 13th November 2024
