Verify if automation script is (still) running
Solved3.09K views24th November 2021Automation protocol script
Joey Vanhalst [SLC] [DevOps Advocate]2.17K 23rd November 2021 0 Comments
From an element, we are executing Automation scripts for certain background tasks. These scripts are executed from a QAction.
A table shows an overview of all tasks and their status (ongoing, scheduled, failed,...). There is currently a timeout configured that updates the record in the table to "Timeout" in case the configured timeout time was surpassed. These tasks are queued so there is only 1 instance of the script running at the same time.
I would like to extend this by verifying from the QAction periodically if the script is actually still running (and didn't for example crash for any reason). This would avoid having to wait unnecessarily for the timeout time.
How can this be done exactly?
Joey Vanhalst [SLC] [DevOps Advocate] Selected answer as best 24th November 2021
Gellynck Jens [SLC]2.72K Posted 23rd November 2021 0 Comments
Hi Joey,
You can also do this from a QAction, Automation script, or any C# application with the following code:
private bool IsAutomationScriptRunning(string scriptName)
var request = new SetAutomationInfoMessage(AutomationInfoType.Maintenance /* 31 */) {
Sa = new SA(new string[] { "LIST_SCRIPTIDS" })
var response = connection.SendSingleResponseMessage<SetAutomationInfoResponseMessage>(request);
if(response is null || response.saRet?.Sa?.Length == 0) {
return false;
// Example: 565;2021-05-07 10:08:50;<scriptname>;Administrator;Running
return response.saRet.Sa.Any(line => line.ContainsInvariant($";{scriptName};") && line.ContainsInvariant(";Running"));
