Verify cloud connection from automation script
Solved1.61K views18th January 2024Automation script cloud-connection
Seppe Dejonckheere [SLC] [DevOps Enabler]2.80K 18th January 2024 0 Comments
Is it possible to determine if a cluster is cloud connected using an automation script?
I would also need to be able to determine which exact agents in the cluster provide the cloud connection and which ones don’t.
Kr,
Seppe Dejonckheere [SLC] [DevOps Enabler] Selected answer as best 18th January 2024
Jordy Ampe [SLC] [DevOps Advocate]2.00K Posted 18th January 2024 4 Comments
Hi Seppe,
I think you should be able to use this message to know if the DMS is registered with dataminer.services (= cloud-connected).
As far as I know there are no other messages to know what ‘agents’ do provide the cloud-connection, as it could even be a proxy server without DMA installed on it.
Wkr
Jordy Ampe [SLC] [DevOps Advocate] Edited comment 28th April 2025
Jordy Ampe [SLC] [DevOps Advocate] commented 18th January 2024
Another message “ValidateDmsExternalAuthenticationRequest” will check if your current cloud registration token is still valid with dataminer.services (if not a ‘renew’ is needed)
Another message “IsAccountCloudLinkedRequest” will check if the DataMiner user sending this message (so the user who executes the automation script in your case) is linked to a dataminer.services account and if so it will also return the email address
Jordy Ampe [SLC] [DevOps Advocate] commented 6th February 2024
After some investigation we found out these messages are not included in the automation/slnettypes nugets and we will have look if we can make them available in the future.
Jordy Ampe [SLC] [DevOps Advocate] commented 28th April 2025
It's possible to get the dataminer.services IDs for the organization & DMS (meaning the DMS is cloud connected) using the ChatIntegrationHelper Nuget (https://www.nuget.org/packages/Skyline.DataMiner.DcpChatIntegrationHelper) like this: `var chatIntegrationHelper = new ChatIntegrationHelperBuilder().Build(); var identity = chatIntegrationHelper.GetDataMinerServicesDmsIdentity();`. This method would throw a ChatIntegrationException("The DMS is not registered with dataminer.services.") in case the DMS is not registered with dataminer.services (anymore).
