Using Variables inside a shape group
Solved1.43K views13th August 2024group InitVar set var
joel_ joly531 13th August 2024 0 Comments
Hello DOJO
We have a template visio form, that can be used on many parts of our monitoring.
All elements are defined inside a list of variables.
The var:
The settings of shape:
The result:
It works fine, each time we need a new view, we just have to change the variables and the new view fit perfectly on the place we put it.
But if we group shapes, the variables are not retreived, and the shapes stay empty. I tried to use ForcePropertyXX without success.
Copy a shape and put it in a group:
The shape is not able to display the element from the variable.
Is it impossible to use a variable inside a group, or do I miss something?
joel_ joly Selected answer as best 13th August 2024
Miguel Obregon [SLC] [DevOps Catalyst]23.46K Posted 13th August 2024 1 Comment
Hi Joly,
Can you try adding the following shape data to the group:
  • View: [this view]
  • Options: NoAlarmColorFill
  • Enabled: False
I performed a small test and after setting these shape data to the group, child shapes were able to resolve the session variables. The shape data Options and Enabled are used to avoid making the group shape display the alarm of the view and disable the link to the view, respectively.
Hope it helps.
joel_ joly Posted new comment 13th August 2024
joel_ joly commented 13th August 2024
Perfect, Thank you Miguel
View:[This View] was missing
All is now OK
