using TrapInfo
Solved2.58K views30th March 2022trapinfo
Stefan Schedletzky10 17th February 2022 2 Comments
Hey,
I'm trying to use a trap receiver which retrieves all traps for an element.
Including TrapInfo:
using Skyline.DataMiner.Library.Protocol.Snmp.Trap;
But compilation failed:
(9,25): error CS0234: The type or namespace name 'Library' does not exist in the namespace 'Skyline.DataMiner' (are you missing an assembly reference?)
(24,13): error CS0246: The type or namespace name 'TrapInfo' could not be found (are you missing a using directive or an assembly reference?)
So what is the correct namespace?
Stefan Schedletzky Selected answer as best 30th March 2022
Miguel Obregon [SLC] [DevOps Catalyst] commented 17th February 2022
Hi Stefan,
To further help with your question, can you include the driver version of the generic trap receiver driver that you are using for tests?
Stefan Schedletzky commented 17th February 2022
Hi Miguel,
I’m directly testing with a new device. It’s a Siemens SPS which can only send traps.
Flavio Meneses [SLC] [DevOps Enabler]1.35K Posted 30th March 2022 0 Comments
Hi Stefan,
Do you have DataMiner installed locally? Can you check in DIS settings the configured paths for imported DLLs? In case DataMiner is not locally installed, most probably you will need to manually update the DLLs locations.
In case the following checkbox is enabled, QA63000 should be automatically generated when you use features from the class library (e.g., TrapInfo).
Kind regards,
