Using script condition count(*) in Correlation Rule
Solved1.63K views4th July 2023
Ken O'Connor622 5th June 2023 0 Comments
I have two correlation rules both deisgned to provide the same output. One is based upon standard filters and works. The other uses a script condition 'count(*)>=4'  and does not.
RULE WITHOUT COUNT (WORKS)
RULE WITH COUNT (DOES NOT WORK)
The rule with the count added does not seem to produce a correlated alarm. I have tried various combinations of filtering etc. Can I have some advice?
Thanks
Jan-Klaas Kesteloot [SLC] [DevOps Advocate]1.58K Posted 5th June 2023 2 Comments
The rule condition apply to the buckets you've created with the 'group by'. However, using the 'trigger on single events only', I believe there are no buckets being kept in memory and as such, your condition will  never match.
Have you tried to uncheck 'trigger on single events only'?
Ken O'Connor [DevOps Member] commented 5th June 2023
Hi Thanks for the response. I have got it working to a fashion.. but the trigger on single events is stil checked, However, Can you put a logical operator on the script.. so for example if I want to test for count(*) >= 4 combined with count(*) =< 10 . So anything 4 to 10 inclusive.
Jan-Klaas Kesteloot [SLC] [DevOps Advocate] commented 5th June 2023
I’m afraid the only supported operators are the ones documented in https://docs.dataminer.services/user-guide/Advanced_Modules/Correlation/Correlation_rule_syntax/Condition_format.html.
However, you can add another script condition with ‘Add filter’ and combine the script & filter conditions with logical operators.
