Using Reg Ex in Filters
Solved3.01K views11th July 2023
Ken O'Connor701 25th August 2022 1 Comment
I have alarms comin in with the parameter description containing XXXXXX or YYYYYY
I want to filter these using Reg Ex . I have tried the following:-
^(?!(XXXXXX|YYYYYY))
(XXXXXX|YYYYYY).*\s+\1(\s+|$)
and others..
So Alarm A comes in with the field Parameter.Description = 'XXXXXX'
then Alarm B comes in with the field Parameter.Description = 'YYYYYY'
the Alarm C comes in with the field Parameter.Description = 'ZZZZZZ'
So I want to use a reg ex to filter on the XXXXXX or YYYYYY only.
Ive Herreman [SLC] [DevOps Enabler] commented 25th August 2022
Hi Ken,
Where are you applying the filters?
e.g. a visio, the alarm console, dashboards
Ive Herreman [SLC] [DevOps Enabler]14.80K Posted 25th August 2022 0 Comments
I made a quick test, which seem to do the trick.
Would the configuration as shown below work for you?
This gives me the following output
