Using custom dll’s on a DaaS system.
Solved1.99K views11th December 2024automation scipt DaaS DLL
Michiel Vanthuyne [SLC] [DevOps Advocate]4.82K 9th December 2024 0 Comments
For some of our automation scripts we use some custom created dll's, so functions can be shared over all automation scripts. On an on-premise system, we place these in the Files or the ProtocolScripts folder so the automation scripts can access them. Is there any way to upload these dll's to a DaaS system so we can continue to use the automation scripts that use these dll's?
Michiel Vanthuyne [SLC] [DevOps Advocate] Selected answer as best 11th December 2024
Jens Vandewalle [SLC] [DevOps Advocate]10.07K Posted 9th December 2024 0 Comments
Hi Michiel,
Would it be possible to make use of internal NuGets instead? In that case you can just push your automation scripts, with the NuGets included, to the DaaS system.
Jens Vandewalle [SLC] [DevOps Advocate] Answered question 9th December 2024
