Using Client Test Tools – GetParameterMessage
Solved3.79K views25th November 2021Client Test Tool GetParameter
ryan yahia900 28th October 2021 0 Comments
When using the client test tools using a GetParameterMessage I get this message back for a parameter with the parameter in the xml with these tags:
<Type>read</Type>
            <Interprete>
                <RawType>other</RawType>
                <LengthType>next param</LengthType>
                <Type>string</Type>
            </Interprete>
            <Display>
                <RTDisplay>false</RTDisplay>
            </Display>
            <Measurement>
                <Type>string</Type>
            </Measurement>
        </Param>
Does anyone know what's causing the error below?
ryan yahia Selected answer as best 25th November 2021
Miguel Obregon [SLC] [DevOps Catalyst]23.83K Posted 28th October 2021 2 Comments
Hi Ryan,
Please could you let us know the type of the parameter where are you trying to get the value (single parameter or a column parameter)? Please find below an example for a single parameter:
As Jens mentioned, could it be the case that you are using an incorrect ID?
Miguel Obregon [SLC] [DevOps Catalyst] Posted new comment 28th October 2021
ryan yahia commented 28th October 2021
Thank you for you example. I am trying to get the value of a single parameter
Miguel Obregon [SLC] [DevOps Catalyst] commented 28th October 2021
Hi Ryan,
If this is the case, can you check first if you are pointing to an existing element?
When you right click on an element and select ‘Properties’, you will find the ID in the format DMAID/EID. The first number corresponds to the DMAID and the second number corresponds to the element ID. Can you try with these IDs and let us know if it works?
