Using Client Test Tools – GetParameterMessage
Solved3.52K views25th November 2021Client Test Tool GetParameter
ryan yahia900 28th October 2021 0 Comments
When using the client test tools using a GetParameterMessage I get this message back for a parameter with the parameter in the xml with these tags:
<Type>read</Type>
            <Interprete>
                <RawType>other</RawType>
                <LengthType>next param</LengthType>
                <Type>string</Type>
            </Interprete>
            <Display>
                <RTDisplay>false</RTDisplay>
            </Display>
            <Measurement>
                <Type>string</Type>
            </Measurement>
        </Param>
Does anyone know what's causing the error below?
ryan yahia Selected answer as best 25th November 2021
Gellynck Jens [SLC]2.72K Posted 28th October 2021 1 Comment
One of the cases that causes this exception is when the ParameterId property of the GetParameterMessage does not exist.
ryan yahia Posted new comment 28th October 2021
ryan yahia commented 28th October 2021
The parameter does exist, I believe it is a case of it not being a displayed parameter as mentions by Jens Vandewalle
