Using AWS SDK to Develop AWS CloudWatch Driver
Solved2.50K views11th July 2023AWS AWS CloudWatch
Saddam Zourob [DevOps Member]363 2nd September 2021 0 Comments
We are trying to build an internal AWS CloudWatch Driver that uses the AWS SDK Library. The new driver is only required to return the list of alarms that are currently present on the CloudWatch Alarms List. The following code should be retrieving the list of alarms:
However, we keep getting the following exception in the logs every time we try to retrieve the alarms.
Note that we use the following DLLs in the solution:
  • AWSSDK.Core.dll
  • AWSSDK.CloudWatch.dll
Amazon.Runtime.AmazonServiceException: A WebException with status ConnectFailure was thrown. ---> System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 52.94.50.138:443
at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
at System.Net.HttpWebRequest.GetRequestStream(TransportContext& context)
at System.Net.HttpWebRequest.GetRequestStream()
at Amazon.Runtime.Internal.HttpRequest.GetRequestContent()
at Amazon.Runtime.Internal.HttpHandler`1.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.Internal.PipelineHandler.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.Internal.Unmarshaller.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.Internal.ErrorHandler.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.Internal.WebExceptionHandler.HandleException(IExecutionContext executionContext, WebException exception)
at Amazon.Runtime.Internal.ExceptionHandler`1.Handle(IExecutionContext executionContext, Exception exception)
at Amazon.Runtime.Internal.ErrorHandler.ProcessException(IExecutionContext executionContext, Exception exception)
at Amazon.Runtime.Internal.CallbackHandler.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.Internal.Signer.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.Internal.EndpointDiscoveryHandler.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.Internal.CredentialsRetriever.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.Internal.RetryHandler.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.Internal.EndpointResolver.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.Internal.Marshaller.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.Internal.ErrorCallbackHandler.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.Internal.MetricsHandler.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.Internal.RuntimePipeline.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.AmazonServiceClient.Invoke[TResponse](AmazonWebServiceRequest request, InvokeOptionsBase options)
at Amazon.CloudWatch.AmazonCloudWatchClient.DescribeAlarms(DescribeAlarmsRequest request)
at Amazon.CloudWatch.AmazonCloudWatchClient.DescribeAlarms()
at QAction.Run(SLProtocolExt protocol)
Is this related to the security config of the DMA (TLS 1.2)?
Thanks,
Alberto De Luca [DevOps Enabler]5.36K Posted 13th October 2021 0 Comments
Looking at the stack trace, if the address below is the actual interface you have to poll, I'd suggest to check any ACL on the communication channel between DataMiner and the polled IP - I'd expect to poll a private IP in any case: is this feasible in your environment? Do you need to go via that IP address?
