Use VdxPage inside a shape without title/tab control
Solved1.94K views19th July 2024vdxpage Visio Visual Overview
Felix Wesemeier [DevOps Catalyst]2.54K 18th July 2024 0 Comments
Hi community,
I use VdxPage with value “NameOfMyPage” to display a hidden page of my current Visio file inside a shape.
This is working fine.
However, the page name of the hidden page is shown on top of the shape like a title or a tab control.
As I only want to display one page, it would be nice to hide this title.
Is there an option I can use to hide it?
Felix Wesemeier [DevOps Catalyst] Selected answer as best 19th July 2024
Toon Casteele [SLC] [DevOps Enabler]7.45K Posted 19th July 2024 1 Comment
Using a VdxPage without View/Element link on the shape will always show the tab control. Adding Element/View shape data (even if it’s linking to the same one as the one you’re on with [this view] or similar) will show no tab control if there is only one.
Felix Wesemeier [DevOps Catalyst] commented 19th July 2024
Hi Toon,
adding View [this view] works fine, thank you!
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 18th July 2024 1 Comment
Hi Felix,
Can you try the hidden option?
Hope it helps.
Felix Wesemeier [DevOps Catalyst] Edited comment 18th July 2024
Felix Wesemeier [DevOps Catalyst] commented 18th July 2024
Hi Miguel,
the “overview system 1” page already uses the hidden option, so it is not included in the main tab control.
However, the page name (marked in red) is shown inside the vdxpage shape.
