Use Tooltip and Click Action for the same shape in a grid component
Solved1.91K views12th March 2025Dashboard grid component LCA
Felix Wesemeier [DevOps Catalyst]2.53K 26th September 2024 0 Comments
Hi community,
in a Dashboard / LCA I would like to place a shape (cycle)
  • that displays the severity color of an alarm
  • shows a tooltip on mouseover
  • executes a component action when clicked
Using a drawn cycle allows the conditional coloring and the click action.
Using a text component and draw the cycle with HTML allows conditional coloring and the tooltip.
Drawing a transparent cycle on top of the Text Component disables the tooltip functionality.
Is their any way to use a drawn cycle with a tooltip
or any way to execute a component action when clicking on a text component?
Best regards,
Felix
Robin Debel [SLC] [DevOps Enabler] Answered question 12th March 2025
Robin Debel [SLC] [DevOps Enabler]2.36K Posted 12th March 2025 1 Comment
Hi Felix,
Happy to share we've just merged the feature which allows you to have actions on text shapes. The change will be included in the 10.5.5 web release.
Felix Wesemeier [DevOps Catalyst] Posted new comment 12th March 2025
Felix Wesemeier [DevOps Catalyst] commented 12th March 2025
Hi Robin,
this is great, thanks!
