Use Tooltip and Click Action for the same shape in a grid component
Solved2.09K views12th March 2025Dashboard grid component LCA
Felix Wesemeier [DevOps Catalyst]2.54K 26th September 2024 0 Comments
Hi community,
in a Dashboard / LCA I would like to place a shape (cycle)
  • that displays the severity color of an alarm
  • shows a tooltip on mouseover
  • executes a component action when clicked
Using a drawn cycle allows the conditional coloring and the click action.
Using a text component and draw the cycle with HTML allows conditional coloring and the tooltip.
Drawing a transparent cycle on top of the Text Component disables the tooltip functionality.
Is their any way to use a drawn cycle with a tooltip
or any way to execute a component action when clicking on a text component?
Best regards,
Felix
Robin Debel [SLC] [DevOps Advocate] Answered question 12th March 2025
Wout Mahieu [SLC] [DevOps Catalyst]12.34K Posted 30th September 2024 5 Comments
Hi Felix
It is currently not possible to execute an action when clicking on a text shape. The solution is to cover it with a transparent shape. This also means that the tooltip of the text will no longer be shown on hover.
Since this use case make a lot of sense, I have created a task on our backlog to allow actions to be added to text shapes as well.
Felix Wesemeier [DevOps Catalyst] Posted new comment 13th February 2025
Felix Wesemeier [DevOps Catalyst] commented 14th October 2024
Hi Wout,
can you tell me when or in which version you plan to implement this?
Wout Mahieu [SLC] [DevOps Catalyst] commented 14th October 2024
Hi Felix,
We currently have no date/release planned where this will be implemented. The task is near the top of our backlog.
Felix Wesemeier [DevOps Catalyst] commented 13th February 2025
Hi Wout,
do you already know when you'll implement this functionality?
Br,
Felix
Wout Mahieu [SLC] [DevOps Catalyst] commented 13th February 2025
Hi Felix, we are aiming to get this feature available in version 10.5.5 of the Web Apps. This would release April 18th.
Great, thanks.
