Use Tooltip and Click Action for the same shape in a grid component
Solved1.99K views12th March 2025Dashboard grid component LCA
Felix Wesemeier [DevOps Catalyst]2.53K 26th September 2024 0 Comments
Hi community,
in a Dashboard / LCA I would like to place a shape (cycle)
  • that displays the severity color of an alarm
  • shows a tooltip on mouseover
  • executes a component action when clicked
Using a drawn cycle allows the conditional coloring and the click action.
Using a text component and draw the cycle with HTML allows conditional coloring and the tooltip.
Drawing a transparent cycle on top of the Text Component disables the tooltip functionality.
Is their any way to use a drawn cycle with a tooltip
or any way to execute a component action when clicking on a text component?
Best regards,
Felix
Robin Debel [SLC] [DevOps Enabler] Answered question 12th March 2025
Wout Mahieu [SLC] [DevOps Catalyst]12.27K Posted 30th September 2024 5 Comments
Hi Felix
It is currently not possible to execute an action when clicking on a text shape. The solution is to cover it with a transparent shape. This also means that the tooltip of the text will no longer be shown on hover.
Since this use case make a lot of sense, I have created a task on our backlog to allow actions to be added to text shapes as well.
Felix Wesemeier [DevOps Catalyst] Posted new comment 13th February 2025
Felix Wesemeier [DevOps Catalyst] commented 14th October 2024
Hi Wout,
can you tell me when or in which version you plan to implement this?
Wout Mahieu [SLC] [DevOps Catalyst] commented 14th October 2024
Hi Felix,
We currently have no date/release planned where this will be implemented. The task is near the top of our backlog.
Felix Wesemeier [DevOps Catalyst] commented 13th February 2025
Hi Wout,
do you already know when you'll implement this functionality?
Br,
Felix
Wout Mahieu [SLC] [DevOps Catalyst] commented 13th February 2025
Hi Felix, we are aiming to get this feature available in version 10.5.5 of the Web Apps. This would release April 18th.
Great, thanks.
Robin Debel [SLC] [DevOps Enabler]2.36K Posted 12th March 2025 1 Comment
Hi Felix,
Happy to share we’ve just merged the feature which allows you to have actions on text shapes. The change will be included in the 10.5.5 web release.
Felix Wesemeier [DevOps Catalyst] Posted new comment 12th March 2025
Felix Wesemeier [DevOps Catalyst] commented 12th March 2025
Hi Robin,
this is great, thanks!
