Upload automation script does not show script code in Dataminer Cube
Solved1.42K views28th January 2025
David Crome [DevOps Member]381 27th January 2025 1 Comment
I am using VS 2022 with DIS 3.1.4 to create a new automation script. In the script tag of the automation script xml file it does not show the code but a reference to the cs file:
<Script>
<Exe id=”1″ type=”csharp”>
<Value><![CDATA[[Project:Auto Route_1]]]></Value>
<!–<Param type=”debug”>true</Param>–>
<Message></Message>
</Exe>
</Script>
When I publish the automation script it shows not the code but the reference:
Of course I can not validate this, it shows me directly 3 errors, because this is not valid C# code. But can Dataminer find the cs file or is this wrong?
In the logs I get these errors, trying to run this script by an own crated scheduler task:
… CScriptLoader::LoadScriptFromXML|DBG|-1|(Script Auto Route) Execute ID 1 is used more than once
… CScriptLoader::LoadScriptFromXML|DBG|-1|Could not load script Auto Route
… CScriptLoader::StartScript|DBG|-1|The script could not be loaded (AUTO ROUTE)
Where can I set the ID? I only created a scheduler task and set that it should run this Auto Route script
Why could it not load the script?
Thanks for your help.
David
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th January 2025
David Crome [DevOps Member] commented 27th January 2025
I found the error, it was because I used the same ID ("1") for a scriptParameter and the exe element.
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 28th January 2025 0 Comments
It looks like this question has already been answered with the comment above. To make it clear that this question no longer requires an answer, I have added this pro forma answer so that we can mark it as resolved.
