Upgrade finished with errors
Solved1.72K views30th May 202410.4 upgrade upgrade
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.41K 1st April 2024 0 Comments
I upgraded a FO setup with hostnames environment to 10.4.0.0-14109 (from 10.3.11.0-13456+HF), however there were some errors (see below).
Can you let me know why these errors happened and if there are any actions that are needed to be taken ?
After the upgrade I was able to connect to the system and there were no errors from Cube. Everything looked ok on first sight.
The version info after the upgrade:
Versions for agent :
Server version    : 10.4.0.0-14109
Client version     : 10.4.2409.2458-485239c4
Launcher version: 10.3.2324.534-f6dadc78
The errors and notices of the upgrade:
10.42.193.34     Error      Failed to extract ‘Files\Microsoft.Extensions.Logging.Abstractions.dll’: Access is denied. (FileException)
10.42.193.34     Error      Failed to extract ‘Files\System.Buffers.dll’: Access is denied. (FileException)
10.42.193.34     Error      Failed to extract ‘Files\System.Memory.dll’: Access is denied. (FileException)
10.42.193.34     Error      Failed to extract ‘Files\System.Numerics.Vectors.dll’: Access is denied. (FileException)
10.42.193.34     Error      Failed to extract ‘Files\System.Runtime.CompilerServices.Unsafe.dll’: Access is denied. (FileException)
10.42.193.34     Error      Checking central database failed: MySql.Data.MySqlClient.MySqlException (0x80004005): Unable to connect to any of the specified MySQL hosts.
10.42.193.34     Notice   Failed to extract ‘Files\Microsoft.Extensions.Logging.Abstractions.dll’: Access is denied. (FileException)
10.42.193.34     Notice   Failed to extract ‘Files\System.Buffers.dll’: Access is denied. (FileException)
10.42.193.34     Notice   Failed to extract ‘Files\System.Memory.dll’: Access is denied. (FileException)
10.42.193.34     Notice   Failed to extract ‘Files\System.Numerics.Vectors.dll’: Access is denied. (FileException)
10.42.193.34     Notice   Failed to extract ‘Files\System.Runtime.CompilerServices.Unsafe.dll’: Access is denied. (FileException)
10.42.193.34     Notice   Installation failed for DataMiner APIGateway 0.0.2.18775 with exit code 1603, retrying…
10.42.193.34     Notice   [FAILED] Delete C:\Skyline DataMiner\Files\Microsoft.Extensions.Logging.Abstractions.dll (2 The system cannot find the file specified.)
10.42.193.34     Notice   Attempting to terminate processes that are still using C:\Skyline DataMiner\Files\Microsoft.Extensions.Logging.Abstractions.dll
10.42.193.34     Notice   [FAILED] (retry) Delete C:\Skyline DataMiner\Files\Microsoft.Extensions.Logging.Abstractions.dll (2 The system cannot find the file specified.)
10.42.193.34     Notice   [FAILED] Failed renaming ‘C:\Skyline DataMiner\Files\Microsoft.Extensions.Logging.Abstractions.dll’ (cause 2 oserror 2)
10.42.193.34     Notice   [FAILED] Delete C:\Skyline DataMiner\Files\System.Buffers.dll (2 The system cannot find the file specified.)
10.42.193.34     Notice   Attempting to terminate processes that are still using C:\Skyline DataMiner\Files\System.Buffers.dll
10.42.193.34     Notice   [FAILED] (retry) Delete C:\Skyline DataMiner\Files\System.Buffers.dll (2 The system cannot find the file specified.)
10.42.193.34     Notice   [FAILED] Failed renaming ‘C:\Skyline DataMiner\Files\System.Buffers.dll’ (cause 2 oserror 2)
10.42.193.34     Notice   [FAILED] Delete C:\Skyline DataMiner\Files\System.Memory.dll (2 The system cannot find the file specified.)
10.42.193.34     Notice   Attempting to terminate processes that are still using C:\Skyline DataMiner\Files\System.Memory.dll
10.42.193.34     Notice   [FAILED] (retry) Delete C:\Skyline DataMiner\Files\System.Memory.dll (2 The system cannot find the file specified.)
10.42.193.34     Notice   [FAILED] Failed renaming ‘C:\Skyline DataMiner\Files\System.Memory.dll’ (cause 2 oserror 2)
10.42.193.34     Notice   [FAILED] Delete C:\Skyline DataMiner\Files\System.Numerics.Vectors.dll (2 The system cannot find the file specified.)
10.42.193.34     Notice   Attempting to terminate processes that are still using C:\Skyline DataMiner\Files\System.Numerics.Vectors.dll
10.42.193.34     Notice   [FAILED] (retry) Delete C:\Skyline DataMiner\Files\System.Numerics.Vectors.dll (2 The system cannot find the file specified.)
10.42.193.34     Notice   [FAILED] Failed renaming ‘C:\Skyline DataMiner\Files\System.Numerics.Vectors.dll’ (cause 2 oserror 2)
10.42.193.34     Notice   [FAILED] Delete C:\Skyline DataMiner\Files\System.Runtime.CompilerServices.Unsafe.dll (2 The system cannot find the file specified.)
10.42.193.34     Notice   Attempting to terminate processes that are still using C:\Skyline DataMiner\Files\System.Runtime.CompilerServices.Unsafe.dll
10.42.193.34     Notice   [FAILED] (retry) Delete C:\Skyline DataMiner\Files\System.Runtime.CompilerServices.Unsafe.dll (2 The system cannot find the file specified.)
10.42.193.34     Notice   [FAILED] Failed renaming ‘C:\Skyline DataMiner\Files\System.Runtime.CompilerServices.Unsafe.dll’ (cause 2 oserror 2)
10.42.193.98     Notice   dms-tabledefinitions could not be found.
10.42.193.98     Notice   dms-customdataindices could not be found.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th May 2024
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.41K Posted 30th May 2024 0 Comments
Rerunning the upgrade package resolved the problem.
