Unit test: Extension method (NotifyProtocol.GetKeys)
Solved1.81K views29th March 2023extension method Mock NotifyProtocol protocol Unit Test
Andries Deklerck [SLC] [DevOps Member]492 28th March 2023 0 Comments
Hi
Is there a way to use the NotifyProtocol.GetKeys extension method in a unit test?
I'm using Skyline.DataMiner.Dev.Protocol version 10.1.0.1.
Andries Deklerck [SLC] [DevOps Member] Selected answer as best 29th March 2023
Laurens Moutton [SLC] [DevOps Enabler]9.61K Posted 28th March 2023 0 Comments
Mocking an extension method directly is not possible.
Since RN27995 this method has become part of the SLProtocol interface. If you're using 10.2.0 (or 10.1.1) as Protocol Dev pack then you should be able to mock the GetKeys method directly.
Regards,
Laurens Moutton [SLC] [DevOps Enabler] Answered question 28th March 2023
