Unit Test – BadImageFormatExceptiuon – Could not load file or assembly ‘SLManagedScripting’
Solved1.82K views23rd July 2024Unit Test
Fenta Alemahu [SLC] [DevOps Advocate]1.42K 23rd July 2024 0 Comments
Hi all,
We have an existing protocol which has unit tests. If the platform target of the unit test project is set to x86, running the tests in Visual Studio succeeds. If the platform target is set to x64 or Any CPU, running the tests in VS fails. In both scenarios, when I push the protocol solution to the CI/CD pipeline, it fails and gives the same exception as it gives in VS when the platform target is set to x64 or Any CPU. The error message is the one shown below.
Error message in VS
Error message in the CI/CD pipeline
How is it possible to fix such issues?
Fenta Alemahu [SLC] [DevOps Advocate] Selected answer as best 23rd July 2024
João Severino [SLC] [DevOps Enabler]14.78K Posted 23rd July 2024 0 Comments
Hi Fenta,
You need to configure the Directory.Build.props file to have something like this
<Project>
<PropertyGroup>
<PlatformTarget>x86</PlatformTarget>
</PropertyGroup>
</Project>
This will indicate the pipeline to use x86 for the build instead of any
