Unit in ParametersSummary
287 views13th February 2026parameterssummary unit Visio
Koen Bouckhout [SLC] [DevOps Advocate]1.57K 13th February 2026 0 Comments
Hello Dojo,
I am trying to display the Max Value of two bitrate values using the ParametersSummary shape data.
In cube each of the two values are nicely displayed as kbps or Mbps depending on the actual value.
For example in Cube I see "1.56 Mbps" but the value displayed by the ParameterSummary on Visio is "1560302.91 bps".
Is there any way to manipulate the display such that it also shows the value in Mbps or Kbps iso bps? Or would there be an alternative to reach the same goal?
Thanks!
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 13th February 2026
Miguel Obregon [SLC] [DevOps Catalyst]22.39K Posted 13th February 2026 0 Comments
Hi Koen,
In case it is not possible to use ParameterSummary together with dynamic units, another approach is to perform this aggregation in a GQI query. I double checked and confirmed that aggregated values takes into account dynamic units.
Hope it helps.
Jarno Lernou [SLC] [DevOps Enabler]5.79K Posted 13th February 2026 1 Comment
Hi Koen,
Normally when displaying parameters, you have the following shape-level option to use for enabling or disabling dynamic units. I'm not sure though if this is also evaluated for the ParametersSummary Shape Data.: DynamicUnits=[true/false]. I wasn't able to test, because I couldn't immediately find a quick test element, but it's easily tested on your side I guess.
Kind Regards,
Jarno
Koen Bouckhout [SLC] [DevOps Advocate] Posted new comment 13th February 2026
Koen Bouckhout [SLC] [DevOps Advocate] commented 13th February 2026
Thanks Jarno for the suggestion. Ive suggested the same a little earlier. I tested that option on the ParametersSummary Shape Data but it didn't have any effect unfortunately.
