Unit in front of number
Solved2.50K views3rd May 2023display protocol protocol parameter units
7
Arne Maes [SLC] [DevOps Member]896 17th March 2023 0 Comments
Is it possible to define a unit that is displayed in front of the number?
for example € 5, instead of the default 5 €.
I could then also use to define other numeric values that are not really units like interface numbers.
for example ETH 3, instead of just 3.
Pieter Van Compernolle [SLC] [DevOps Enabler] Answered question 3rd May 2023
Jorge Dias [SLC] [DevOps Enabler]5.36K Posted 17th March 2023 0 Comments
Hi Arne,
No that is not possible, also doesn’t seem correct to use Units for another purpose than to display the unit of a parameter.
For your example, you can use a retrieved column that you fill with the value that you need.
Arne Maes [SLC] [DevOps Member] Selected answer as best 22nd March 2023
Pieter Van Compernolle [SLC] [DevOps Enabler]4.44K Posted 3rd May 2023 1 Comment
Hi Arne
On the Data displays (Cube/Monitoring app), this will not be possible indeed, but do know that in dashboards and low code apps, you can achieve that.
You’ll need a GQI query with a column manipulation or custom operator (currently in soft launch).
Arne Maes [SLC] [DevOps Member] Posted new comment 3rd May 2023
Arne Maes [SLC] [DevOps Member] commented 3rd May 2023
Thank you, that’s good to know.
