unit conversion with a param and protocol loading error
Solved1.17K views18th July 2024load protocol failed Params units
julien laborie34 6th March 2024 2 Comments
Hi all!
I've been trying to solve a problem for a while now, but without success. Maybe someone can help me!
I have two problems with one param:
- I get SNMP data that is equal to 77.5 (units in kHz). When I put it into dataminer it gives me 775.
- I've had a protocol failure like this:
pid: 9003 reason: System.ArgumentException: Cannot convert measurementtype to one of the existing types: digital threshold
at Skyline.DataMiner.Net.Tools.GetMeasurementType(String strType)
at Skyline.DataMiner.Net.MessageBuilder.BuildParameterInfo(ParameterInfoSourceType sourceType, String[][] xmlData, String context, List`1 otherParams, List`1 cachedStrings)
at Skyline.DataMiner.Net.Parser.ProtocolHelper.BuildOneParameterInfo(List`1 allParameters, ParameterInfoSourceType sourceType, String[][] oneParameterData, Boolean isControlProtocol, Dictionary`2 paramsToDuplicate, List`1 cachedStrings, String context)
Here is the parameter in question:
<Param id="9003" trending="false">
<Name>PeakThres</Name>
<Description>Peak Alarm Threshold</Description>
<Information>
<Subtext>
<![CDATA[Peak Alert Threshold from 65kHz to 90kHz.]]>
</Subtext>
</Information>
<Type>read</Type>
<Interprete>
<RawType>numeric text</RawType>
<Type>string</Type>
</Interprete>
<SNMP>
<Enabled>true</Enabled>
<OID type="complete">1.3.6.1.4.1.41853.1.1.4.2.8.1.3</OID>
<Type>octetstring</Type>
</SNMP>
<Display>
<RTDisplay>true</RTDisplay>
<Units>kHz</Units>
<Decimals>1</Decimals>
</Display>
<Alarm>
<Monitored>true</Monitored>
</Alarm>
<Measurement>
<Type>number</Type>
</Measurement>
</Param>
Many thanks for your help!
Julien
Marieke Goethals [SLC] [DevOps Catalyst] commented 4th June 2024
I see that this question has been inactive for some time. Do you still need help with this? If you’ve been able to solve this with Tom’s answer, could you select the answer? Or if you’ve found a solution of your own in the meantime, could you post an answer of your own for the reference of other users?
As this question has now been open for a long time and there has been no further reaction from you, I will now close it. If you still want more information about this, could you post a new question?
Tom Waterbley [SLC] [DevOps Enabler]10.01K Posted 6th March 2024 1 Comment
Hi Julien,
Can you please try changing the interprete type from string to double?
<Interprete>
<Type>double</Type>
</Interprete>
The GetMeasurementType method seems to be called with "digital threshold" as argument. Had a quick look at what that method is doing, and apparently the value of the argument needs to be "threshold digital" instead. I'm not sure what is calling the that method though.
julien laborie commented 6th March 2024
Thanks for your reply Tom!
Done !
From what I found I have either for Measurement>Type>Digital Threshold :
“Obsolete. Allows an analogue signal to be interpreted as a digital signal by assigning it a threshold value. ”
Otherwise for Measurement>Threshold :
“This element must only be specified if Protocol.Params.Param.Measurement.Type is set to “digital threshold”.”
But I don’t know, it’s not really what I want, I think.
