Undeletable Element
Solved1.80K views23rd August 2024
Mark Christopher Famini [DevOps Member]191 14th April 2024 3 Comments
When we relocated the DM server to a different subnet and restart the Server … The Deleted elements appeared in the main view and when we try to delete it … it gives an error:
Error Trapped: The element is unknown
// how to clean up this mess of numerous unwanted elements?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 23rd August 2024
I see that this question has been inactive for some time. Do you still need more information for this? If not, could you select Edib’s answer to indicate that the question is resolved?
Mark Christopher Famini [DevOps Member] commented 18th July 2024
no option to set = “resolved”
Marieke Goethals [SLC] [DevOps Catalyst] commented 19th July 2024
To mark the question as resolved, just select the ✓ icon to the left of the answer.
Edib Šupić [SLC] [DevOps Enabler]2.55K Posted 15th April 2024 0 Comments
Hello Mark,
Can you please navigate to C:\Skyline DataMiner\Elements and try deleting unwanted elements directly from there? You should stop the DM before attempting to delete them.
Hope this helps,
Cheers
Mark Christopher Famini [DevOps Member]191 Posted 18th July 2024 0 Comments
Question is resolved:
[quote]
Ghost elements attached to production version of protocol. After taking necessary precautions deleting this version and restarting the agents removed the elements.
[unquote]
Mark Christopher Famini [DevOps Member] Answered question 18th July 2024
